Einleitung
Users will be able to replace lost, broke, or scratched volume control buttons for the Samsung Galaxy Core Prime. This will enable the user to more easily control volume and improve the overall aesthetics of the smartphone.
Was du brauchst
Turn the smartphone off by using the power button on the right-hand side.
Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
Use a Phillips #00 screwdriver to remove the eight 4mm screws from the midframe.
In diesem Schritt verwendetes Werkzeug:iFixit Opening Tool$1.99
Use an iFixit Opening Tool or a similarly shaped tool like a guitar pick to lift the mid-frame.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
