Zum Hauptinhalt wechseln
Samsung Galaxy J1 Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy J1 Motherboard Replacement, Midframe: Schritt 1, Bild 1 von 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Motherboard Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy J1 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Motherboard Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy J1 Motherboard Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy J1 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Samsung Galaxy J1 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
  6. Samsung Galaxy J1 Motherboard Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy J1 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use the flat end of a spudger disconnect the digitizer connector.
  7. Samsung Galaxy J1 Motherboard Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy J1 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
  8. Samsung Galaxy J1 Motherboard Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy J1 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the front-facing camera.
  9. Samsung Galaxy J1 Motherboard Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy J1 Motherboard Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy J1 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
  10. Samsung Galaxy J1 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
  11. Samsung Galaxy J1 Motherboard Replacement: Schritt 11, Bild 1 von 2 Samsung Galaxy J1 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the rear camera.
Abschluss
22 weitere Nutzer:innen haben diese Anleitung absolviert.
Sean Kramer
1.506 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S5-G4, Eyestone Spring 2018 Mitglied von USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Mitglieder
4 Kommentare
can you plz give use a amazon link to part
Sean Gynn - Antwort
Very good illustration..where can I get a motherboard?
Isaac Samuels - Antwort
Where can I get a motherboard for this phone Samsung J100?
I need the details of the motherboard
FUN FIRST - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 39
Insgesamt: 6,692
