Zum Hauptinhalt wechseln
Samsung Galaxy Mega 2 Battery Replacement
Was du brauchst
  1. Samsung Galaxy Mega 2 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before begining, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once you get the corner released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Battery Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Mega 2 Battery Replacement: Schritt 2, Bild 2 von 2
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on bottom of the battery and gently lift up.
    • Remove the battery.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 1,311
