Zum Hauptinhalt wechseln
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
Was du brauchst
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: Schritt 1, Bild 1 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: Schritt 1, Bild 2 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: Schritt 1, Bild 3 von 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: Schritt 2, Bild 1 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: Schritt 2, Bild 2 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: Schritt 2, Bild 3 von 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: Schritt 3, Bild 1 von 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: Schritt 3, Bild 2 von 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: Schritt 4, Bild 1 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: Schritt 4, Bild 2 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: Schritt 4, Bild 3 von 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: Schritt 5, Bild 1 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: Schritt 5, Bild 2 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: Schritt 5, Bild 3 von 3
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: Schritt 6, Bild 1 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: Schritt 6, Bild 2 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: Schritt 6, Bild 3 von 3
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: Schritt 7, Bild 1 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: Schritt 7, Bild 2 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: Schritt 7, Bild 3 von 3
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: Schritt 8, Bild 1 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: Schritt 8, Bild 2 von 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: Schritt 8, Bild 3 von 3
    • Carefully lift and remove the camera from its position.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 14-4, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,409
