Zum Hauptinhalt wechseln
Samsung Galaxy Prevail 2 Vibrator Replacement
Was du brauchst
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: Schritt 1, Bild 1 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: Schritt 1, Bild 2 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: Schritt 1, Bild 3 von 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: Schritt 2, Bild 1 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: Schritt 2, Bild 2 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: Schritt 2, Bild 3 von 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: Schritt 3, Bild 1 von 2 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: Schritt 3, Bild 2 von 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: Schritt 4, Bild 1 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: Schritt 4, Bild 2 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: Schritt 4, Bild 3 von 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: Schritt 5, Bild 1 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: Schritt 5, Bild 2 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: Schritt 5, Bild 3 von 3
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: Schritt 6, Bild 1 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: Schritt 6, Bild 2 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: Schritt 6, Bild 3 von 3
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: Schritt 7, Bild 1 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: Schritt 7, Bild 2 von 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: Schritt 7, Bild 3 von 3
    • With plastic prying tool, lift up the vibration motor.
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: Schritt 8, Bild 1 von 1
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 14-4, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 991
