Zum Hauptinhalt wechseln
Samsung Galaxy Prevail Rear Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Prevail Rear Speaker Replacement, Rear Speaker: Schritt 1, Bild 1 von 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Speaker Replacement: Schritt 2, Bild 1 von 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The motherboard will now be accessible.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Speaker Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Prevail Rear Speaker Replacement: Schritt 5, Bild 2 von 2
    • Using the spudger, carefully lift upward to remove the speaker assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
Abschluss
USF Tampa, Team 17-6, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 216
