Zum Hauptinhalt wechseln
Samsung Galaxy S II T989 Speaker Replacement
Was du brauchst
  1. Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: Schritt 1, Bild 3 von 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: Schritt 2, Bild 1 von 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: Schritt 2, Bild 2 von 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  3. Samsung Galaxy S II T989 Speaker Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy S II T989 Speaker Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy S II T989 Speaker Replacement: Schritt 3, Bild 3 von 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  4. Samsung Galaxy S II T989 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: Schritt 4, Bild 2 von 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: Schritt 4, Bild 3 von 3
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Joshua King
1.378 Reputation
9 Anleitungen geschrieben
Clemson, Team 1-5, Benson Spring 2014 Mitglied von Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Mitglieder
3 Kommentare
speaker jumper ways
Muhammad azan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 1,510
