Zum Hauptinhalt wechseln
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
Was du brauchst
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: Schritt 1, Bild 1 von 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 2, Bild 1 von 1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 3, Bild 1 von 1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: Schritt 4, Bild 1 von 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: Schritt 5, Bild 1 von 1
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: Schritt 6, Bild 1 von 1
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 7, Bild 1 von 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 7, Bild 2 von 2
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 8, Bild 1 von 1
    Kaufen
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 9, Bild 1 von 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 9, Bild 2 von 2
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 10, Bild 1 von 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 10, Bild 2 von 2
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 11, Bild 1 von 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 11, Bild 2 von 2
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 12, Bild 1 von 3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 12, Bild 2 von 3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 12, Bild 3 von 3
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 13, Bild 1 von 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: Schritt 13, Bild 2 von 2
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Richard
30.239 Reputation
11 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.525 Anleitungen geschrieben
Ein Kommentar
Thank You so much!
Peter Handless - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 5,230
