Einleitung
Use this guide to replace the display assembly, which includes the front glass, digitizer, and home button cable.
Was du brauchst
Einführungsvideo
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot.
Remove the microSD card from the phone.
Use the sharp tip of a spudger to pry the home button cable connector straight up off its socket.
Place a heated iOpener on the left side of the phone for at least 90 seconds.
Reheat the iOpener and place it on the right half of the phone.
Insert the edge of an opening pick underneath the bottom right side of the front glass.
Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone.
Slide the opening pick across the top of the phone, being very careful not to insert the pick too deeply.
Slide the opening pick down along the left half of the phone stopping at the lower left corner.
Slide the opening pick all the way to the bottom left corner of the phone, making sure it is securely placed.
Slide the very end of the opening pick across the bottom edge of the display to separate the last of the remaining adhesive.
Insert an opening pick under the soft button icons on the display and pry the button cables down off the inside of the front panel.
Use the sharp tip of a spudger to lift the front panel assembly cable connector straight up off its socket on the motherboard.
Safely remove the front panel assembly from phone.
535 weitere Nutzer:innen haben diese Anleitung absolviert.
36 Kommentare
Be aware that the LCD is glued not just at the edges, but also in the middle (the orange areas in the photos for Step 20. These can adhere strongly enough to cause the LCD to crack. Don't ask how I know that.
I cracked it this way, so yeah. Any way to get the glue fluetly enough to get the LCD off the rest of the Phone? (the LCD and digitalizer is cracked anyway)
Onfortunately I read this to late. Many thanks anyway for confirming I'm not the only one ;)
Been there man. Had my Samsung Galaxy S5 Active pull one of those numbers. not a fun time.
Just found out about that, during my first time. Thanks for the tip.
