Zum Hauptinhalt wechseln
Samsung Galaxy S8 Plus Displayeinheit (mit Rahmen) austauschen
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
33 weitere Nutzer:innen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
Jeff Suovanen
429.579 Reputation
259 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.525 Anleitungen geschrieben
5 Kommentare
something to note, not sure if the guy mentions in video (it’s german, I didn't actually watch it) :
If you try and test the new display before you reassembled the mid frame, you will get a temperature warning. reinstall all screws and mid frame then test, should be good.
also, this is the only method you should attempt this repair, as the official samsung screens will come like this, with frame. If not, its not original, don’t waste your time or money on sh!tty parts
Andrew - Antwort
Agreed! I love my OEM Samsung Service Box Display
Ethan Bain - Antwort
Best video I’ve seen of the S8 teardown. Agree with what Andrew said above, check the midframe to see all the extra small parts are there. To check everything works, you can turn on the phone with after connecting the display to the motherboard, and puting the internals back together (everything but gluing the front and back pieces). Be careful to put all the screws back in place- the motherboard needs a tight connection to components on the midframe (like the power button and audio speaker) to work. Good luck!
Michael M - Antwort
Can I buy the screen replacement
Christian lares - Antwort
How can i by samsung Galaxy 8+ screen?
Nguse Hayelom - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 40
Letzte 30 Tage: 136
Insgesamt: 31,308
