Zum Hauptinhalt wechseln
Samsung Galaxy Sol Rear Camera Replacement
Was du brauchst
  1. Samsung Galaxy Sol Rear Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Rear Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Rear Camera Replacement, Rear Camera: Schritt 3, Bild 1 von 1
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
  4. Samsung Galaxy Sol Rear Camera Replacement: Schritt 4, Bild 1 von 1
    • After you have removed all the screws, take a credit card or plastic tool to lift the screen. You will go all around the border of the phone.
  5. Samsung Galaxy Sol Rear Camera Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Sol Rear Camera Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Sol Rear Camera Replacement: Schritt 5, Bild 3 von 3
    • After removing the grey part of the phone, you will need to remove the motherboard by detaching all the chips.
  6. Samsung Galaxy Sol Rear Camera Replacement: Schritt 6, Bild 1 von 1
    • Once you detach the chips, remove the hard drive to access the rear camera.
  7. Samsung Galaxy Sol Rear Camera Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy Sol Rear Camera Replacement: Schritt 7, Bild 2 von 2
    • To remove the rear camera, flip the tab upward and then pull the camera straight out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 480
