Zum Hauptinhalt wechseln
Samsung Galaxy TabPro S Front-Facing Camera Replacement
Was du brauchst
  1. Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: Schritt 1, Bild 1 von 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: Schritt 1, Bild 2 von 2
    • Remove the back of the tablet by prying the plastic back using a flat tool.
    • When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
  2. Samsung Galaxy TabPro S Front-Facing Camera Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
    • Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
  3. Samsung Galaxy TabPro S Front-Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
    • Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
  4. Samsung Galaxy TabPro S Front-Facing Camera Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: Schritt 4, Bild 2 von 2
    • Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
    • Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
  5. Samsung Galaxy TabPro S Front-Facing Camera Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
Abschluss
IUPUI, Team 3-4, Harley Spring 2022 Mitglied von IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 269
