Zum Hauptinhalt wechseln
Samsung Galaxy Y Charging port and headphone jack Replacement
Was du brauchst
  1. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: Schritt 1, Bild 1 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: Schritt 1, Bild 2 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: Schritt 2, Bild 1 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: Schritt 2, Bild 2 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: Schritt 2, Bild 3 von 3
    • Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 3, Bild 3 von 3
    • Use metal pry tool to separate the interior back panel from the interior hardware and screen.
  4. Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the orange motherboard connection, then remove interior hardware from the front screen display.
  5. Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
    • If the motherboard is cracked or damaged, then replace with a new one.
  6. Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Y Charging port and headphone jack Replacement: Schritt 6, Bild 3 von 3
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alyissa
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 631
