Zum Hauptinhalt wechseln
Samsung PL200 Lens Replacement
Was du brauchst
  1. Samsung PL200 Lens Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung PL200 Lens Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
  2. Samsung PL200 Lens Replacement: Schritt 2, Bild 1 von 3 Samsung PL200 Lens Replacement: Schritt 2, Bild 2 von 3 Samsung PL200 Lens Replacement: Schritt 2, Bild 3 von 3
    • Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
    • This will release the spring loaded battery.
    • Use your fingers to remove the old battery.
  3. Samsung PL200 Lens Replacement: Schritt 3, Bild 1 von 3 Samsung PL200 Lens Replacement: Schritt 3, Bild 2 von 3 Samsung PL200 Lens Replacement: Schritt 3, Bild 3 von 3
    • Insert the new battery into the battery slot.
    • Push it down with your finger until the blue release switch re-engages over top of the battery.
    • Close the battery/SD card compartment.
  4. Samsung PL200 Lens Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Remove the six 3 mm external screws from the camera base using the Phillips #000 screwdriver.
  5. Samsung PL200 Lens Replacement: Schritt 5, Bild 1 von 3 Samsung PL200 Lens Replacement: Schritt 5, Bild 2 von 3 Samsung PL200 Lens Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tools and your fingers to pull the external cover off.
  6. Samsung PL200 Lens Replacement: Schritt 6, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the 3 mm screw holding the circuit board.
    • Use a pair of tweezers to detach the two ribbon cables connecting the circuit board to the camera.
    • Remove the circuit board.
  7. Samsung PL200 Lens Replacement: Schritt 7, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 7, Bild 2 von 2
    • Flip the LCD screen forward and remove the two 3 mm screws holding the metal midframe using a Phillips #000 screwdriver.
    • Remove the midframe using an opening tool.
  8. Samsung PL200 Lens Replacement: Schritt 8, Bild 1 von 1
    • Remove the front cover. It will come off fairly easily.
  9. Samsung PL200 Lens Replacement: Schritt 9, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 9, Bild 2 von 2
    • Lift the black strip and the ribbon will easily come out.
    • After doing this, the LCD screen will be separated from the camera.
  10. Samsung PL200 Lens Replacement, SD card: Schritt 10, Bild 1 von 2 Samsung PL200 Lens Replacement, SD card: Schritt 10, Bild 2 von 2
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
    • Once opened, the SD card should be visible.
  11. Samsung PL200 Lens Replacement: Schritt 11, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 11, Bild 2 von 2
    • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector.
    • This will cause the SD card to raise up enough to allow you to grab it with your fingers.
    • Use your fingers to remove the old SD card.
  12. Samsung PL200 Lens Replacement: Schritt 12, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 12, Bild 2 von 2
    • Insert the new SD card into the SD card slot.
    • Make sure to push it down all the way until it clicks and remains flush with battery.
  13. Samsung PL200 Lens Replacement, Lens: Schritt 13, Bild 1 von 2 Samsung PL200 Lens Replacement, Lens: Schritt 13, Bild 2 von 2
    • Remove the two black 3 mm screws from the right side of the camera using a Phillips #000 screwdriver.
    • Remove the five silver 3 mm screws from the camera's side and bottom using a Phillips #000 screwdriver.
  14. Samsung PL200 Lens Replacement: Schritt 14, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 14, Bild 2 von 2
    • Use a plastic opening tool and your fingers to pry off the external cover.
  15. Samsung PL200 Lens Replacement: Schritt 15, Bild 1 von 3 Samsung PL200 Lens Replacement: Schritt 15, Bild 2 von 3 Samsung PL200 Lens Replacement: Schritt 15, Bild 3 von 3
    Kaufen
    • Remove the single 3 mm screw securing the circuit board with a Phillips #000 screwdriver.
    • Remove any leftover tape on the circuit board and screen.
    • Unplug and remove the wires from the circuit board using a set of tweezers.
  16. Samsung PL200 Lens Replacement: Schritt 16, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 16, Bild 2 von 2
    • Flip the LCD screen forward and out to the side.
    • Use a Phillips #000 screwdriver to remove the two 3 mm screws beneath the LCD screen.
    • Remove the metal brace using the Plastic Opening Tool.
  17. Samsung PL200 Lens Replacement: Schritt 17, Bild 1 von 2 Samsung PL200 Lens Replacement: Schritt 17, Bild 2 von 2
    • Flip the ZIF connector's locking bar vertically, then gently remove the ribbon cable.
    • Remove the screen.
  18. Samsung PL200 Lens Replacement: Schritt 18, Bild 1 von 1
    • Remove the front cover of the camera using your fingers and a plastic opening tool.
  19. Samsung PL200 Lens Replacement: Schritt 19, Bild 1 von 1
    • Set the screen and metal brace aside.
    • Open the camera’s battery compartment on the bottom part of the camera.
  20. Samsung PL200 Lens Replacement: Schritt 20, Bild 1 von 1
    • Remove the two 3 mm corner screws that secure the motherboard, with a Phillips #000 screwdriver.
    • Remove any leftover tape that may still be on the motherboard.
  21. Samsung PL200 Lens Replacement: Schritt 21, Bild 1 von 3 Samsung PL200 Lens Replacement: Schritt 21, Bild 2 von 3 Samsung PL200 Lens Replacement: Schritt 21, Bild 3 von 3
    • Use tweezers to remove the tape from the bottom of the camera.
    • Then use the tweezers to disconnect the lens unit cord at the bottom of the camera from the motherboard.
    • Remove the last 3 mm screw securing the motherboard with a Phillips #00 screwdriver.
  22. Samsung PL200 Lens Replacement: Schritt 22, Bild 1 von 3 Samsung PL200 Lens Replacement: Schritt 22, Bild 2 von 3 Samsung PL200 Lens Replacement: Schritt 22, Bild 3 von 3
    • Use tweezers to unplug the small lens unit cord from the camera frame on the backside of the camera.
    • Gently lift the lens unit from the frame.
    • Separate the lens unit, motherboard, and camera.
  23. Samsung PL200 Lens Replacement: Schritt 23, Bild 1 von 3 Samsung PL200 Lens Replacement: Schritt 23, Bild 2 von 3 Samsung PL200 Lens Replacement: Schritt 23, Bild 3 von 3
    • Use tweezers to disconnect the small ribbon cable from the motherboard.
    • Then use the tweezers to remove the first large lens unit ribbon cable from the motherboard.
    • Finally, use the tweezers to remove the second large lens unit ribbon cable from the motherboard.
  24. Samsung PL200 Lens Replacement: Schritt 24, Bild 1 von 1
    • You have now separated the lens unit. Replace it with a functional lens unit at this stage, and reassemble the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Clemson, Team 15-7, Shirley Winter 2015 Mitglied von Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,015
