Zum Hauptinhalt wechseln
Samsung Series 7XE700T1A Volume Button Replacement
Was du brauchst
  1. Samsung Series 7XE700T1A Volume Button Replacement, Back panel: Schritt 1, Bild 1 von 1
    • Remove the microSD card before attempting to open the device. Wedge the opening tools inside the device and move it around the perimeter (between the black and silver panels, not between the glass and the black panel) until you have loosened the adhesive that is keeping it together.
  2. Samsung Series 7XE700T1A Volume Button Replacement: Schritt 2, Bild 1 von 2 Samsung Series 7XE700T1A Volume Button Replacement: Schritt 2, Bild 2 von 2
    • With your hands, open up the back panel, separating it from the tablet.
  3. Samsung Series 7XE700T1A Volume Button Replacement, Volume Button: Schritt 3, Bild 1 von 1
    • Now that the back panel has been removed, using your fingers, push out the volume button from the inside.
Abschluss
james
463 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 325
