Zum Hauptinhalt wechseln
Sharp EL-510RN Calculator Battery Replacement
Was du brauchst
  1. Sharp EL-510RN Calculator Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Sharp EL-510RN Calculator Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Calculator Battery Replacement: Schritt 2, Bild 1 von 3 Sharp EL-510RN Calculator Battery Replacement: Schritt 2, Bild 2 von 3 Sharp EL-510RN Calculator Battery Replacement: Schritt 2, Bild 3 von 3
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Calculator Battery Replacement: Schritt 3, Bild 1 von 3 Sharp EL-510RN Calculator Battery Replacement: Schritt 3, Bild 2 von 3 Sharp EL-510RN Calculator Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Calculator Battery Replacement: Schritt 4, Bild 1 von 3 Sharp EL-510RN Calculator Battery Replacement: Schritt 4, Bild 2 von 3 Sharp EL-510RN Calculator Battery Replacement: Schritt 4, Bild 3 von 3
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Calculator Battery Replacement: Schritt 5, Bild 1 von 1
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
Abschluss
Harish Kugathasalingam
121 Reputation
1 Anleitung geschrieben
York University, Team 4-5, Allen Fall 2022 Mitglied von York University, Team 4-5, Allen Fall 2022
YORK-ALLEN-F22S4G5
2 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 42
Insgesamt: 566
