Zum Hauptinhalt wechseln
Sharper Image SVC430 Lens Replacement
Was du brauchst
  1. Sharper Image SVC430 Lens Replacement, Sharper Image SVC430 Disassembly: Schritt 1, Bild 1 von 2 Sharper Image SVC430 Lens Replacement, Sharper Image SVC430 Disassembly: Schritt 1, Bild 2 von 2
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Lens Replacement: Schritt 2, Bild 1 von 2 Sharper Image SVC430 Lens Replacement: Schritt 2, Bild 2 von 2
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Lens Replacement: Schritt 3, Bild 1 von 3 Sharper Image SVC430 Lens Replacement: Schritt 3, Bild 2 von 3 Sharper Image SVC430 Lens Replacement: Schritt 3, Bild 3 von 3
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Lens Replacement: Schritt 4, Bild 1 von 2 Sharper Image SVC430 Lens Replacement: Schritt 4, Bild 2 von 2
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Lens Replacement: Schritt 5, Bild 1 von 1
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Lens Replacement: Schritt 6, Bild 1 von 3 Sharper Image SVC430 Lens Replacement: Schritt 6, Bild 2 von 3 Sharper Image SVC430 Lens Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Lens Replacement: Schritt 7, Bild 1 von 1
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Lens Replacement: Schritt 8, Bild 1 von 1
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Lens Replacement: Schritt 9, Bild 1 von 1
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Lens Replacement: Schritt 10, Bild 1 von 1
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Lens Replacement, Lens: Schritt 11, Bild 1 von 1
    • Behind the lens, use the metal screwdriver to unscrew the two screws holding the lens in place on the circuit board.
  12. Sharper Image SVC430 Lens Replacement: Schritt 12, Bild 1 von 1
    • The lens should easily remove from the circuit board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 202
