Einleitung
Do shoes with a worn-out buckle sit around? No worries! We'll help you replace that buckle so you can wear your favorite shoes again. Say goodbye to the problem and hello to the steps that make it easy. Let's get those shoes back on your feet – it's as simple as that!
Was du brauchst
Examine the back of the strap to locate the seam.
Gently unthread the stitches from the back, and work your way to the front with the seam ripper.
Let's begin with the threading process.
To begin, thread the needle by passing the thread through its eye.
Then, align the unstitched strap with the old stitching onto the shoe, as this will act as your guide.
Once it's aligned, use the previous stitching holes as a guide to begin stitching.
After completing the process, proceed to tie the thread.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
