Zum Hauptinhalt wechseln
Sky 6.0Q Battery Replacement
Was du brauchst
  1. Sky 6.0Q Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Battery Replacement: Schritt 2, Bild 1 von 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Battery Replacement: Schritt 3, Bild 1 von 2 Sky 6.0Q Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Battery Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the gold cord extending from the battery to the top electronic board.
    • Use the nylon spudger to help pry up the battery attachment.
    • To reattach the gold cord and battery attachment connection, gently press piece back in place.
  5. Sky 6.0Q Battery Replacement: Schritt 5, Bild 1 von 1
    • Use the nylon spudger to get underneath the battery and separate it from the phone back.
    • There is a white, milky adhesive so be careful to not rip or puncture the battery during removal.
  6. Sky 6.0Q Battery Replacement: Schritt 6, Bild 1 von 1
    • Once separated, remove battery and replace with a new battery.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Monica Difato
429 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G3, Hovde Fall 2018 Mitglied von IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 36
Insgesamt: 2,350
