Zum Hauptinhalt wechseln
Sony Alpha A3000 Motherboard Replacement
Was du brauchst
  1. Sony Alpha A3000 Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: Schritt 1, Bild 2 von 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Motherboard Replacement: Schritt 2, Bild 1 von 2 Sony Alpha A3000 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Motherboard Replacement: Schritt 3, Bild 1 von 2 Sony Alpha A3000 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 Sony Alpha A3000 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 Motherboard Replacement: Schritt 5, Bild 1 von 2 Sony Alpha A3000 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 Motherboard Replacement: Schritt 6, Bild 1 von 2 Sony Alpha A3000 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the metal casing.
  8. Sony Alpha A3000 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 Motherboard Replacement: Schritt 9, Bild 1 von 2 Sony Alpha A3000 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Finally remove the motherboard from the casing.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 4-4, Meier Fall 2015 Mitglied von USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Then loose the plug all the motherboard?
kongre172 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 29
Insgesamt: 2,388
