Einleitung
If your Cable Port Door is not functioning properly you may need to replace it.
Was du brauchst
Open the cable port door.
Identify and unscrew the two Phillips #000 screws.
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Spudger$4.99
Use the heavy duty spudger to lift up the port door compartment.
Remove the port door from the plastic body.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
