Einleitung
In the event that your eye cup is damaged or lost, you may need to replace it. This guide will show you how to replace it with a new one.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Spudger$4.99
Identify the bottom of the eye cup
Using the heavy duty spudger, push the eye cup upward to remove it from the camera body.
Using the Phillips #000 screwdriver, unscrew the two screws from the eye cup.
Remove the back side of the eye cup.
Push down on the hard plastic part of the eye cup and remove it from the cushion.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
