Zum Hauptinhalt wechseln
Sony Alpha ILCE-6000 E-mount Replacement
Was du brauchst
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: Schritt 1, Bild 1 von 1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: Schritt 2, Bild 1 von 1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: Schritt 3, Bild 1 von 2 Sony Alpha ILCE-6000 E-mount Replacement: Schritt 3, Bild 2 von 2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: Schritt 4, Bild 1 von 2 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: Schritt 4, Bild 2 von 2
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: Schritt 5, Bild 1 von 3 Sony Alpha ILCE-6000 E-mount Replacement: Schritt 5, Bild 2 von 3 Sony Alpha ILCE-6000 E-mount Replacement: Schritt 5, Bild 3 von 3
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: Schritt 6, Bild 1 von 3 Sony Alpha ILCE-6000 E-mount Replacement: Schritt 6, Bild 2 von 3 Sony Alpha ILCE-6000 E-mount Replacement: Schritt 6, Bild 3 von 3
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: Schritt 7, Bild 1 von 1
    • Replace the plastic E-mount ring with a new one.
Abschluss
Yirga Yilma
221 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team 1-4, Rose Winter 2017 Mitglied von UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - Antwort
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 70
Insgesamt: 3,686
