Zum Hauptinhalt wechseln
Sony Alpha NEX-6 Back Case Replacement
Was du brauchst
  1. Sony Alpha NEX-6 Back Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
  2. Sony Alpha NEX-6 Back Case Replacement: Schritt 2, Bild 1 von 1
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
  3. Sony Alpha NEX-6 Back Case Replacement: Schritt 3, Bild 1 von 1
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
  4. Sony Alpha NEX-6 Back Case Replacement, Battery compartment screws: Schritt 4, Bild 1 von 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
  5. Sony Alpha NEX-6 Back Case Replacement, Bottom screws: Schritt 5, Bild 1 von 1
    • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
  6. Sony Alpha NEX-6 Back Case Replacement, Side screws: Schritt 6, Bild 1 von 1
    • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
    • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
  7. Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: Schritt 7, Bild 1 von 2 Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: Schritt 7, Bild 2 von 2
    • Starting with the battery compartment gently begin to separate the back case front the camera.
    • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
    • Gently lift the back case away from the camera an slide it down to completely remove the back case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Clayton Dale
1.067 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 11-2, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Mitglieder
14 Anleitungen geschrieben
3 Kommentare
At {STEP 7} you will notice the last parts to release are the flash button / record button areas. This is particularly tricky.
The flash button release seems to be attached inside, so take care. In my case I did not remove the back case completely due to this.
The corner where the record button is requires extra force to slide down / pry out.
Re-assembly : Take note of these parts.
- the PLAY button flexible circuit has a small hole which fits into a pin on the back case. It is important to align this correctly or your play & AEL button may not function.
- The eye piece has a flexible circuit on its right side which tucks behind a small tab - take care this is not dislodged or it could be damaged when re assembling.
Riquez JP - Antwort
Does your team know how to fix the Flash Pop-up button ? It seems the flash for me and others is stuck open and can't be clicked back down. Can you assist ?
rullor - Antwort
Can you please let me know how to replace the battery door? Thank you.
Richard Bullough - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 3,553
