Zum Hauptinhalt wechseln
Sony Alpha a7s II Diopter Replacement
Was du brauchst
  1. Sony Alpha a7s II Diopter Replacement, Diopter: Schritt 1, Bild 1 von 1
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7s II Diopter Replacement: Schritt 2, Bild 1 von 1
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7s II Diopter Replacement: Schritt 3, Bild 1 von 1
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7s II Diopter Replacement: Schritt 4, Bild 1 von 1
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7s II Diopter Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 37
Insgesamt: 2,104
