Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement
Was du brauchst
  1. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 2, Bild 2 von 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 3, Bild 2 von 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Outer Shell: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 6, Bild 1 von 1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 7, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 7, Bild 2 von 2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 8, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 9, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 10, Bild 1 von 1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 11, Bild 1 von 1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 12, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 12, Bild 2 von 2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 13, Bild 1 von 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 13, Bild 2 von 2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: Schritt 14, Bild 1 von 3 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: Schritt 14, Bild 2 von 3 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: Schritt 14, Bild 3 von 3
    • Using the plastic opening tool, remove the back casing of the device.
  15. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Wrist Strap Holster: Schritt 15, Bild 1 von 1
    • Using a Phillips #00 screwdriver , remove two silver 3mm screws from the side of the device.
  16. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: Schritt 16, Bild 1 von 1
    • Using your fingers, remove the silver wrist band holster from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 451
