Einleitung
If the lens assembly of your Sony Cyber-Shot DSC-W120 is damaged, this guide will explain how to dissassemble the camera so it can safely be removed.
Was du brauchst
Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
Use a plastic opening tool to separate the front case of the camera, and gently remove it.
Use a plastic opening tool to remove the silver piece on the left side of the camera.
Separate the tape connecting the lens to the rest of the camera using tweezers.
Remove the lens.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
