Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-H200 SD Door Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: Schritt 1, Bild 2 von 2
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 2, Bild 1 von 1
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 3, Bild 1 von 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 4, Bild 2 von 2
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 5, Bild 2 von 2
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 6, Bild 1 von 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 7, Bild 1 von 1
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: Schritt 9, Bild 1 von 1
    • Remove the door.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,565
