Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 3 von 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: Schritt 4, Bild 2 von 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: Schritt 5, Bild 2 von 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: Schritt 6, Bild 1 von 1
    • Grasp the CCD Sensor Module and remove it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
iDeleted
2.101 Reputation
39 Anleitungen geschrieben
Ein Kommentar
where I can buy it?
Francesco Cortese - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 54
Insgesamt: 12,996
