Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-T9 Motherboard Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-T9 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement, Front Cover: Schritt 3, Bild 3 von 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Motherboard Replacement, Back Cover: Schritt 7, Bild 1 von 1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 9, Bild 1 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 9, Bild 2 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 10, Bild 1 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 10, Bild 2 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 Motherboard Replacement, LCD: Schritt 13, Bild 1 von 1
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 15, Bild 1 von 2 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 15, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 16, Bild 1 von 2 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • The LCD is now removed from the camera.
  18. Sony Cyber-shot DSC-T9 Motherboard Replacement, CCD Module: Schritt 18, Bild 1 von 1
    • This is the CCD module.
  19. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  20. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 20, Bild 1 von 1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  21. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 21, Bild 1 von 1
    • The CCD module is now removed from the camera.
  22. Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: Schritt 22, Bild 1 von 2 Sony Cyber-shot DSC-T9 Motherboard Replacement, AV Port: Schritt 22, Bild 2 von 2
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  23. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 23, Bild 1 von 1
    • Remove metal screw plate.
  24. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 24, Bild 1 von 1
    • Use pry stick to pop off ribbon.
  25. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 25, Bild 1 von 1
    • Remove AV port from camera.
  26. Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: Schritt 26, Bild 1 von 2 Sony Cyber-shot DSC-T9 Motherboard Replacement, Motherboard: Schritt 26, Bild 2 von 2
    • The battery cover is located here.
    • Pull away from camera to remove.
  27. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 27, Bild 1 von 2 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 27, Bild 2 von 2
    • Grip on the top and bottom.
    • Pull up and out to remove motherboard and attached parts.
  28. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 28, Bild 1 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 28, Bild 2 von 3 Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 28, Bild 3 von 3
    • Flip motherboard parts to position shown.
    • There are three ribbons still attached to the motherboard.
    • Pull these three ribbons to remove remaining parts from motherboard.
  29. Sony Cyber-shot DSC-T9 Motherboard Replacement: Schritt 29, Bild 1 von 1
    • The motherboard is now removed from the camera.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Clemson, Team 13-1, Benson Spring 2013 Mitglied von Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Mitglieder
20 Anleitungen geschrieben
Ein Kommentar
Superb,thank you very much !!!
Vedrasco Victor Vasili - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 669
