Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-TX7 Front Cover Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: Schritt 1, Bild 2 von 2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 2, Bild 1 von 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 2, Bild 2 von 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 2, Bild 3 von 3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Front Cover: Schritt 3, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 4, Bild 1 von 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 4, Bild 2 von 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 4, Bild 3 von 3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 5, Bild 1 von 1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Cover Replacement: Schritt 6, Bild 1 von 1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
Abschluss
Leslie Mundell
411 Reputation
4 Anleitungen geschrieben
Michigan Tech, Team 1-8, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-8, Lauer Spring 2015
MTU-LAUER-S15S1G8
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 372
