Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W570 Battery Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W570 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the camera upside down.
    • Locate the lock bar and slide to 'open' position.
    • No tools required.
  2. Sony Cyber-shot DSC-W570 Battery Replacement: Schritt 2, Bild 1 von 1
    • Press the blue clip forward, releasing the battery.
    • Remove the battery and replace it with a new one.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Anthony
147 Reputation
1 Anleitung geschrieben
USF Tampa, Team 9-1, Brown Winter 2015 Mitglied von USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Thank you so much. In many moves, my battery charger was lost and it had been a long time before I came across the camera and wondered if I could get a new charger. It was so confusing. Now I'm not sure why I'm to get a charger when you need to buy a new battery? Now that's still confusing. But at least I know where and how to remove the battery. Thank you. Your instructions were so clear even I, at 75, could figure out what to do.
Pat Quackenbush - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 52
Insgesamt: 1,950
