Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 3 von 3
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 4, Bild 1 von 1
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 5, Bild 1 von 1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 6, Bild 2 von 2
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 7, Bild 1 von 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 7, Bild 2 von 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 7, Bild 3 von 3
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 8, Bild 2 von 2
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 9, Bild 1 von 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 9, Bild 2 von 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 9, Bild 3 von 3
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 10, Bild 1 von 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: Schritt 10, Bild 2 von 2
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team S1-G1, Wilson Summer 2017 Mitglied von IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 1,645
