Zum Hauptinhalt wechseln
Sony DSC-RX100MA Screen Replacement
Was du brauchst
  1. Sony DSC-RX100MA Screen Replacement, Back Cover: Schritt 1, Bild 1 von 3 Sony DSC-RX100MA Screen Replacement, Back Cover: Schritt 1, Bild 2 von 3 Sony DSC-RX100MA Screen Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Screen Replacement: Schritt 2, Bild 1 von 3 Sony DSC-RX100MA Screen Replacement: Schritt 2, Bild 2 von 3 Sony DSC-RX100MA Screen Replacement: Schritt 2, Bild 3 von 3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Screen Replacement: Schritt 3, Bild 1 von 3 Sony DSC-RX100MA Screen Replacement: Schritt 3, Bild 2 von 3 Sony DSC-RX100MA Screen Replacement: Schritt 3, Bild 3 von 3
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Screen Replacement: Schritt 4, Bild 1 von 2 Sony DSC-RX100MA Screen Replacement: Schritt 4, Bild 2 von 2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Screen Replacement: Schritt 5, Bild 1 von 3 Sony DSC-RX100MA Screen Replacement: Schritt 5, Bild 2 von 3 Sony DSC-RX100MA Screen Replacement: Schritt 5, Bild 3 von 3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Screen Replacement: Schritt 6, Bild 1 von 2 Sony DSC-RX100MA Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the back cover
  7. Sony DSC-RX100MA Screen Replacement, Screen: Schritt 7, Bild 1 von 3 Sony DSC-RX100MA Screen Replacement, Screen: Schritt 7, Bild 2 von 3 Sony DSC-RX100MA Screen Replacement, Screen: Schritt 7, Bild 3 von 3
    • Move side panel to get access to screws
    • Remove two screws (black 2.5mm) with PH #0 screwdriver
  8. Sony DSC-RX100MA Screen Replacement: Schritt 8, Bild 1 von 2 Sony DSC-RX100MA Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove back panel assembly while still keeping ribbon cable attached
    • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
  9. Sony DSC-RX100MA Screen Replacement: Schritt 9, Bild 1 von 2 Sony DSC-RX100MA Screen Replacement: Schritt 9, Bild 2 von 2
    • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
KC Egger
291 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 21-1, Maness Winter 2017 Mitglied von Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
Any idea where I can get a set or replacement screws? one came out of my LCD joint and I can’t find replacements anywhere online. I’ve even tried Ebay.
Alberto Lora - Antwort
Definately be careful with the gold ribbon cable, looked at mine funny and it just snapped in two.. waiting on a replacement now :(
Connor Quinn - Antwort
I’ve ripped 2 of these before - not fun! Still… cheap enough to buy but delivery took a couple of weeks.
I had a cracked screen so had to take this out to replace as well - problem i’ve had is that although i stuck it down really well (with 3M 1mm double-sided tape, it doesn’t hold great and so the screen has risen a bit and doesn’t sit flush.
Just in the process now of sticking it down again but with a touch of superglue as i need it to hold down a bit better - that should hopefully be me done then :)
Great guide by the way KC Egger - thanks for taking the time to put this together - it’s been a life saver for me!
Jamie Dunkley - Antwort
Where did you purchase your screen, I’ve been trying to find one from Sony parts dealers and can’t find it. Any links would be helpful, thanks.
Ian Cullen -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 44
Insgesamt: 4,487
