Zum Hauptinhalt wechseln
Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement
Was du brauchst
  1. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 2, Bild 1 von 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 3, Bild 1 von 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Battery: Schritt 4, Bild 1 von 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 5, Bild 1 von 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Inner Casing: Schritt 6, Bild 1 von 1
    • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
  7. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 7, Bild 1 von 1
    • Pry open the black casing to access the screw that is holding down the battery holder.
    • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
    • Lift the black inner casing and the battery holder out of the device.
    • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
  8. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, Power Button: Schritt 8, Bild 1 von 1
    • Remove the stylus from the device.
  9. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 9, Bild 1 von 3 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 9, Bild 2 von 3 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 9, Bild 3 von 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
  10. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement, SD and Pro Duo Memory Cards Holder: Schritt 10, Bild 1 von 1
    • Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the memory card holder.
  11. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 11, Bild 1 von 1
    • Using the flat end of the spudger, pry open the brown flap that connects the cardholder to the motherboard.
  12. Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 12, Bild 1 von 2 Sony Reader Touch Edition PRS-600 SD and Pro Duo Memory Card Holders Replacement: Schritt 12, Bild 2 von 2
    • Pull the orange strip out of the opened brown flap.
    • Remove the memory card holder.
Abschluss
Clemson, Team 1-4, Benson Fall 2014 Mitglied von Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 346
