Zum Hauptinhalt wechseln
Sony Vaio Tap 11 Motherboard Replacement
Was du brauchst
  1. Sony Vaio Tap 11 Motherboard Replacement, Screen Assembly: Schritt 1, Bild 1 von 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Motherboard Replacement: Schritt 3, Bild 1 von 2 Sony Vaio Tap 11 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Motherboard Replacement, Battery: Schritt 4, Bild 1 von 1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove the nine 3 mm Phillips #000 screws holding in the motherboard.
  7. Sony Vaio Tap 11 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the black plastic dust shield by gently pulling it up.
    • You'll want to keep the sticky side up so you can replace it when reassembling. This part also functions as a shield for the sensitive camera component!
  8. Sony Vaio Tap 11 Motherboard Replacement: Schritt 8, Bild 1 von 3 Sony Vaio Tap 11 Motherboard Replacement: Schritt 8, Bild 2 von 3 Sony Vaio Tap 11 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Before removing the motherboard, there are a few cables to disconnect.
    • Disconnect the cable connected to the top of the display.
    • Disconnect the power jack connector on the left side of the screen.
    • Disconnect the daughterboard connector located above and to the right of the WiFi chip slot.
  9. Sony Vaio Tap 11 Motherboard Replacement: Schritt 9, Bild 1 von 2 Sony Vaio Tap 11 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Gently pull the motherboard out by pulling from the right side of the board and flip it so that the motherboard now sits where the battery was and the underside is now visible.
    • There is still one cable to remove!
    • Remove the speaker connector located next to the SSD slot.
    • You may now remove the motherboard from the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team 1-2, Harley Fall 2015 Mitglied von IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 2,514
