Zum Hauptinhalt wechseln
Spiral Bound Notebook Cover Replacement
Was du brauchst
  1. Spiral Bound Notebook Cover Replacement, Cover: Schritt 1, Bild 1 von 2 Spiral Bound Notebook Cover Replacement, Cover: Schritt 1, Bild 2 von 2
    • Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
  2. Spiral Bound Notebook Cover Replacement: Schritt 2, Bild 1 von 3 Spiral Bound Notebook Cover Replacement: Schritt 2, Bild 2 von 3 Spiral Bound Notebook Cover Replacement: Schritt 2, Bild 3 von 3
    • Uncoil the free end of the spiral.
  3. Spiral Bound Notebook Cover Replacement: Schritt 3, Bild 1 von 3 Spiral Bound Notebook Cover Replacement: Schritt 3, Bild 2 von 3 Spiral Bound Notebook Cover Replacement: Schritt 3, Bild 3 von 3
    • Push the spiral end back through the binding hole and pull it out.
  4. Spiral Bound Notebook Cover Replacement: Schritt 4, Bild 1 von 1
    • Repeat previous step until spiral is removed.
  5. Spiral Bound Notebook Cover Replacement: Schritt 5, Bild 1 von 1
    • Take the damaged cover and place it over the cardstock, aligning them at the edges.
  6. Spiral Bound Notebook Cover Replacement: Schritt 6, Bild 1 von 3 Spiral Bound Notebook Cover Replacement: Schritt 6, Bild 2 von 3 Spiral Bound Notebook Cover Replacement: Schritt 6, Bild 3 von 3
    • Trace the cover edges.
  7. Spiral Bound Notebook Cover Replacement: Schritt 7, Bild 1 von 2 Spiral Bound Notebook Cover Replacement: Schritt 7, Bild 2 von 2
    • Trace the cover binding holes.
  8. Spiral Bound Notebook Cover Replacement: Schritt 8, Bild 1 von 3 Spiral Bound Notebook Cover Replacement: Schritt 8, Bild 2 von 3 Spiral Bound Notebook Cover Replacement: Schritt 8, Bild 3 von 3
    • Using a hole punch, punch out the traced holes on the cardstock sheet.
  9. Spiral Bound Notebook Cover Replacement: Schritt 9, Bild 1 von 3 Spiral Bound Notebook Cover Replacement: Schritt 9, Bild 2 von 3 Spiral Bound Notebook Cover Replacement: Schritt 9, Bild 3 von 3
    • Cut off the traced edges on the cardstock sheet.
  10. Spiral Bound Notebook Cover Replacement: Schritt 10, Bild 1 von 2 Spiral Bound Notebook Cover Replacement: Schritt 10, Bild 2 von 2
    • Without removing the binding clip, open it and slide the cardstock onto the paper block while making sure their holes aligned.
  11. Spiral Bound Notebook Cover Replacement: Schritt 11, Bild 1 von 3 Spiral Bound Notebook Cover Replacement: Schritt 11, Bild 2 von 3 Spiral Bound Notebook Cover Replacement: Schritt 11, Bild 3 von 3
    • Perform Steps 1 through 4 in reverse to complete the replacement.
Abschluss
To reassemble your device, follow instructions 1 - 4 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Abel Mbaziira
220 Reputation
1 Anleitung geschrieben
York University, Team O-31, Woodhouse Winter 2023 Mitglied von York University, Team O-31, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG31
1 Mitglied
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 29
Letzte 30 Tage: 128
Insgesamt: 1,994
