Zum Hauptinhalt wechseln
TOSHIBA Satellite E45W-C4200X Battery Replacement
Was du brauchst
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: Schritt 1, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 2, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 2, Bild 2 von 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 3, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 4, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 5, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 5, Bild 2 von 2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 37
Insgesamt: 2,063
