Zum Hauptinhalt wechseln
Toshiba Satellite 1805-S177 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
    • The hard drive is located next to the CD drive.
  2. Toshiba Satellite 1805-S177 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
  3. Toshiba Satellite 1805-S177 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite 1805-S177 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  4. Toshiba Satellite 1805-S177 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
    • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Abschluss
Hannah
227 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 3-5, Johann Summer 2010 Mitglied von Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Mitglieder
24 Anleitungen geschrieben
Ein Kommentar
How can I run a cd if I can't remember my hdd password on my toshiba l645 computer
Vera Hess - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 4,167
