Zum Hauptinhalt wechseln
Toshiba Satellite A105-S4011 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite A105-S4011 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Toshiba Satellite A105-S4011 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Toshiba Satellite A105-S4011 Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Make sure to turn off the laptop, unplug the device and/or remove any batteries.
    • Open the laptop so the display screen is bent fully back with the display facing upward, parallel to the surface you are working on.
    • Wedge the Phillips 00 screwdriver above the F1 key, and separate the top piece of plastic from the body of the laptop. Don't worry about breaking it! You will need to forcefully wedge the screwdriver under the plastic, simultaneously pushing upward and forward.
    • Once that section has popped up, work on pulling the rest of the plastic piece up and out, alternating from left to right.
  2. Toshiba Satellite A105-S4011 Keyboard Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite A105-S4011 Keyboard Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite A105-S4011 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Completely remove the plastic piece from the body of the laptop.
    • Using the Phillips 1 screwdriver, unscrew the two 3mm screws located at the top corners of the keyboard. (See the second picture for additional clarification.)
  3. Toshiba Satellite A105-S4011 Keyboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A105-S4011 Keyboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A105-S4011 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Without yanking, lift the keyboard up carefully.
    • Now that the board is free, cautiously undo and pull free the ribbon that connects the keyboard to the body of the laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 4-14, Maness Spring 2013 Mitglied von Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,512
