Zum Hauptinhalt wechseln
Toshiba Satellite A105-S4284 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  3. Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  4. Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  5. Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite A105-S4284 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
pfedigan
11 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 2-23, Maness Spring 2013 Mitglied von Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 1,464
