Zum Hauptinhalt wechseln
Toshiba Satellite A105-S4284 Speakers Replacement
Was du brauchst
  1. Toshiba Satellite A105-S4284 Speakers Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A105-S4284 Speakers Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Speakers Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  3. Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  4. Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  5. Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 5, Bild 3 von 3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  6. Toshiba Satellite A105-S4284 Speakers Replacement, Casing: Schritt 6, Bild 1 von 3 Toshiba Satellite A105-S4284 Speakers Replacement, Casing: Schritt 6, Bild 2 von 3 Toshiba Satellite A105-S4284 Speakers Replacement, Casing: Schritt 6, Bild 3 von 3
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  7. Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 7, Bild 2 von 2
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  8. Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 8, Bild 2 von 2
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
  9. Toshiba Satellite A105-S4284 Speakers Replacement, Speakers: Schritt 9, Bild 1 von 1
    • Remove the lower half of the laptop and lay upper half on its top.
  10. Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 10, Bild 2 von 2
    • Using the Phillips screwdriver remove the two 4.0mm screws holding each of the speakers housings to the case.
    • Remove the speakers from the case being careful of the wires.
  11. Toshiba Satellite A105-S4284 Speakers Replacement: Schritt 11, Bild 1 von 1
    • The wires for the speakers are color coded.The red and black wires are for the right speaker, and the black and white wires are for the left speaker.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Josh
685 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Cichon Spring 2014 Mitglied von UMass Dartmouth, Team 1-6, Cichon Spring 2014
UMASSD-CICHON-S14S1G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 1,704
