Zum Hauptinhalt wechseln
Toshiba Satellite A205-S5812 DVD Drive Replacement
Was du brauchst
  1. Toshiba Satellite A205-S5812 DVD Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 DVD Drive Replacement: Schritt 2, Bild 1 von 1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 DVD Drive Replacement: Schritt 3, Bild 1 von 1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
  4. Toshiba Satellite A205-S5812 DVD Drive Replacement, DVD Drive: Schritt 4, Bild 1 von 1
    • Remove the 3mm screw using a Phillips #00 screwdriver located beneath the RAM module cover. This screw holds the DVD drive in place.
  5. Toshiba Satellite A205-S5812 DVD Drive Replacement: Schritt 5, Bild 1 von 1
    • Carefully slide the DVD drive out of the side of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 334
