Zum Hauptinhalt wechseln
Toshiba Satellite A210 Optical Disc Drive Replacement
Was du brauchst
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite A210 Optical Disc Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: Schritt 3, Bild 1 von 2 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: Schritt 3, Bild 2 von 2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite A210 Optical Disc Drive Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite A210 Optical Disc Drive Replacement: Schritt 4, Bild 3 von 3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: Schritt 5, Bild 1 von 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: Schritt 5, Bild 2 von 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: Schritt 5, Bild 3 von 3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 17-5, Regan Spring 2013 Mitglied von Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
Question : if i this will my screen start working ng again
jessica johnson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 1,617
