Zum Hauptinhalt wechseln
Toshiba Satellite A215-S4757 Display Screen Replacement
Was du brauchst
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: Schritt 1, Bild 1 von 2 Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: Schritt 1, Bild 2 von 2
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 2, Bild 3 von 3
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 4, Bild 2 von 2
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite A215-S4757 Display Screen Replacement: Schritt 5, Bild 3 von 3
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jacob Brown
409 Reputation
3 Anleitungen geschrieben
Texas Tech, Team 12-2, Bennett Fall 2016 Mitglied von Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 340
