Zum Hauptinhalt wechseln
Toshiba Satellite A215-S7425 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Locate hard drive cover opposite the battery on the lower left corner of the device.
    • Loosen 2 Phillips 4.2 mm size captive screws from cover.
    • Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
  5. Toshiba Satellite A215-S7425 Hard Drive Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Locate the thin plastic tab folded on right side of hard drive case.
    • Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
    • To avoid damage to the hard drive or motherboard connectors; Do not pull plastic tab in a straight up direction.
    • The use of a anti-static wrist strap while working with the hard drive is advise to prevent electrostatic discharge(ESD) from damaging the hard drive.
  6. Toshiba Satellite A215-S7425 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
  7. Toshiba Satellite A215-S7425 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Slide case away from hard drive.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Marianne
647 Reputation
6 Anleitungen geschrieben
Pasco Hernando, Team 5-2, Prince Fall 2014 Mitglied von Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 28
Insgesamt: 929
