Zum Hauptinhalt wechseln
Toshiba Satellite A215-S7425 Optical Drive Replacement
Was du brauchst
  1. Toshiba Satellite A215-S7425 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Optical Drive Replacement, RAM: Schritt 4, Bild 1 von 1
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 7, Bild 3 von 3
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
  8. Toshiba Satellite A215-S7425 Optical Drive Replacement, Optical Drive: Schritt 8, Bild 1 von 1
    Kaufen
    • Locate and remove 1 Phillips 4.2 mm size screw along right side of RAM container.
    • Tweezers may be needed to lift out the screw.
  9. Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite A215-S7425 Optical Drive Replacement: Schritt 9, Bild 2 von 2
    • Push down metal rod until optical drive pops out from its container on the side of the device.
    • To avoid damage to your RAM, make sure RAM is removed and out of the way before beginning this step.
Abschluss
Marianne
647 Reputation
6 Anleitungen geschrieben
Pasco Hernando, Team 5-2, Prince Fall 2014 Mitglied von Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 356
