Was du brauchst
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
Turn device onto its screen side to access the bottom of hinge portion of the screen and push bottom piece of frame along device hinge until it loosens.
Remove 3 Phillips 3.2 mm screws from each side of the metal case around screen.
Pull the screen forward from the top out of the metal frame enough to see the back of the screen.
Hold the screen with one hand and gently remove the display cable from the back side of the screen.
