Zum Hauptinhalt wechseln
Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
Abschluss
Cassie Pickett
201 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S8-G1, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 509
