Zum Hauptinhalt wechseln
Toshiba Satellite A85-S107 15" Battery Replacement
Was du brauchst
  1. Toshiba Satellite A85-S107 15" Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Battery Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite A85-S107 15" Battery Replacement: Schritt 3, Bild 2 von 2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
Abschluss
Travis
31 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 10-38, Amido Spring 2013 Mitglied von Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 534
